Hi all, I am not very technically minded so I’m seeking assistance. I have a 66 plate VW up, just had the clutch and flywheel changed Cambell changed and a service, and radiator replaced. I am now finding it difficult to select second gear when coming down the gears. I don’t seem to have the same issue going up the gears from neutral, first, second etc. 3rd, 4th & 5th seem fine.
My question is is this likely to be connected to the work that has just been done? It worked fine for the first 3 weeks following the work, but something doesn’t feel quite right.
I am reluctant just to take it back to the VW dealer in case I end up with a massive bill just for investigating it like I did for the work I’ve just had done.
No noise or grinding when changing gears, so assuming oil level is ok. Nothing dripping either.
Any advice or assistance would be appreciated
