Heads up folks....£14.50 at 7dayshop on special offer (not that I need another one)
cheap indeed !
cheap indeed !
Lovejimbo said:If you use iTunes to manage your music:
1) Make a folder called 'Music' on the root of the M+M memory card.
2) Navigate to your iTunes music folder located at -
Mac OS X: /Users/username/Music/iTunes/
Windows XP: C:\Documents and Settings\username\My Documents\My Music\iTunes\
Windows Vista: C:\Users\username\Music\iTunes\
Windows 7: C:\Users\username\My Music\iTunes\
3) Within this folder will be separate folders that share the artists names from your music collection. Drag and drop the folders of the artist you want into the 'Music' folder of you M+M memory card.
4) Whenever you get a new album, manage it in iTunes as usual, then navigate to you iTunes music folder and drop that artists folder into you M+M 'Music' folder to update it!
Note: Use iTunes to convert any AAC or iTunes audio tracks to MP3s as detailed in post above, once copied to you M+M use spotlight on Mac, or search on Windows to find the duplicates and delete if you don't want both versions! Be sure to eject the M+M card first, so you don't delete those files thinking they are duplicates too
Hope that helps!
