I am just wondering if the problem that the member has is just that the engine won't pull in 5th from
such a low rpm in top.
I can't see why you would roll onto full throttle at 3k rpm in 5th.
If you consider road speed andmilesper hr in top you are still short of max torque so the issues he reports would happen . The drive train is being laboured. Hence the symptoms.
An to occur on two cars the probability is remote of a mapping fault?
Surely the dealer could validate his "problem".
Here's hoping
Sorry also about my accessory post earlier ( rather non post, thanks to those that helped out , cheers
Here's hoping
