At long last I have found a easy(ish) way to transfer all of my ITunes to and SD card so I can have my music library on my M&M.
Google has an app called Google play - you can use it on any desktop/laptop or Tablet.
Basically when you have opened it (you will need a gmail email address) it allows you to upload all of your ITunes library to a cloud (apart from those songs/albums that are DRM protected)Google play will automatically convert them to MP3 and add any album cover artwork.
This may take quite a while depending on the size of your library and broadband speed - I just left mine overnight.
Once it has uploaded the music to the cloud you can then have the option to download the music and most importantly where to - you need to ensure that your SD card is plugged into your PC, then choose to download all of the music to your SD card.
Google will then get busy putting all of your library on the SD card in the M&M friendly MP3 format - again this will take a while depending on library size and broadband speed (I left mine to it overnight)
You should then be able to put the card in your M&M with all of your music available!!!
I will reiterate that it will not work with DRM protected music, ITunes fortunately has not forced users to have this for a while (so should only be a real issue for older ripped music) but apart from that it works a treat.
