I have to run a high current 12 volt +ve & -ve from the battery to the centre console (low down) is there an obvious bulkhead port or similar I can run through or do I need to drill the bulkhead ??
I thought some of you who have fitted subs or amps might know.
I'm fitting my 2m transciever which can draw a good 15 amps on high power transmit
thanks in advance tech folk.
PD
Edited by: Privatedoc
PD
