How do you use your air con, how should you use your air con ?
Forgetting economy for a moment I leave my air con on all the time, when the fan is on the air con is on and when the fan is off the air con does not operate anyway.
When the weather is sub zero I believe the air con does not kick in ( but I still leave it switched on ) and I think you should try to use it every week to stop the seals drying out.
Any expert views out there !
