1 - 2 of 2 Posts
I am hoping somebody knows about this.
My 2018 model has aircon/heater/vents that is controlled by buttons to select where the air comes out. But the default position of the valve (s) inside the airways is to send it to the footwells. So on (the many) days when I don't actually start the system and it is switched off I get outside air blowing at our feet when driving along.
I would prefer default to be windscreen and side vents (which I could close if draughty). Is there a way to change default to that? (At the moment I have to remember to switch it on and tinker with settings, then switch it off. That keeps my preference but only until I finish that journey and switch the car off.
Default should be wherever you last set it, I don't know of any aircon unit which will change itself after the car is turned off.
1 - 2 of 2 Posts
