1 - 3 of 3 Posts
OK, lots of debate but here is the answer at last
M&M WILL mute internal sources when giving nav instructions
This means :-
SD Card audio
Telephone Audio
Bluetooth Audio
M&M WILL NOTmute external audio sources
This means:-
CD (audio and mp3)
Radio
Aux-in audio
Hope this helps those struggling and apologies for any previous inaccurate information
I thought it did mute the radio when in navigation mode. Or is it that the command takes priority over what's being broadcast in one's mind?
There is certainly a discrepancy between the volume levels of the voice. When choosing a place to go to, the male voice is extremely loud when he wants you to select which route you want to take. Then once under way, the voice is considerably quieter and can be controlled using the options.
Nick, I've been sorting out this conundrum for a while and after testing it today it seems as above
Interestingly, although it mutes the internal sources, it doesn't stop them playing so unlike some navsystems, the audio time continues running.
despite all these foibles, I still think it is a dammed good system and excellent value for money....does way more than a £2500 merc command system!
1 - 3 of 3 Posts
