I'm more and more tempted! errr ...... 😏
Did you install them yourself? Was it that easy? Did you install the tweeters too?
Yep installed them myself and it's reasonably straight forward.
You need a 5mm drill because the oem speakers are riveted in place and then a rivet gun to do the same with the new speakers.
I'd also recommend getting some dyna mat or similar and sound proofing the doors whilst the door cards are off.
They come with the correct surrounds and just plug into the oem plug that's there. You're literally just swapping out speakers.
The oem tweeters are sonic welded (glued) in so need to be cut out with a stanley knife, then the new ones are glue gunned in place, really simple.
Before starting, go on ebay and buy a pack of vw door card clips. As gentle as you want to be getting the door cards off, you'll likely snap a couple and having them handy just removes some of the stress.
This question also to Tom: what kind of crossover do they have ? If it's just a high pass filter inline with the tweeter, that makes installation much easier than if you had one crossover outputting to both woofer and tweeter.
To be honest I'm not entirely sure what a crossover is but a quick Google says the front components have "inline 2 way" and the rear coaxial are also inline? If that helps...
Again, you're not doing anything major with this kit. It just swaps out the OEM speakers for better, more capable ones. I assume it might not even sound any different if you're using the oem headunit/amplification?
