21 - 40 of 64 Posts
On my Up GTI, the headlight switch remains permanently in the “On” position. When the ignition is on, the headlights are on. When the ignition is off, the headlights are off. Period.
Do people really want to replace the OEM switchgear on their new or nearly new VW with unauthenticated alternatives just so that their “hands-free” headlights will only illuminate when it’s Dark ? - If they remained illuminated when the ignition was switched off, with the obvious result of battery drain, then I could understand the logic behind the modification, but this isn’t the case.
+1 from me on this. I am going to keep leaving the lights switch in the on position and stick with the OEM switch. Might go thru a few bulbs a bit quicker but that's the only downside.
Discussion Starter · #23 ·
Must admit there is a lot to be said for this, particularly during the winter months when it makes sense to leave headlights on during daylight hours. Just upgraded my headlights to LEDs, makes an incredible difference to light output and shows how poor the standard halogen bulbs are.
Hi, noob here, I’m considering adding one of the auto light switches to my GTI, i’ve been doing the same as others and leaving the switch on all the time till now which is fine tbh, the main reason i’m considering it is for coming/leaving home functionality, not so much of an issue in the summer months but during these orrible rainy nights it would be nice.
Pretty sure that the coming home feature won't work since, as with your current situation, as soon as the key is removed from the ignition, there is no longer any power going to the headlights.
Hmm, was under the impression that it would work after watching this video:
I know it’s a van but at the end the guy says it’ll work with any VW, oh well if it doesn’t add that feature i won’t be bothering.
I could be wrong, but it's possible that the Transporters headlights remain powered on without key in ignition?
Since the Up cuts power to lights without key I can't see how this would work?
In any case, I have one of these aftermarket Auto light switches in my Up and the coming home function doesn't work. Possibly just been set up wrong though...
The kit I got was Chinese,you need to ‘code’ it once fitted,turn light switch from auto to main beam then back all within 1.5 seconds....worked perfectly after that ,hardest bit was deciphering the awful chinglish instructions !
Thats the one...fitted to our amarok and my up! ! works perfectly
indeed, thats the one
21 - 40 of 64 Posts
