Sorry for my english
The biggest problem for me was that ive got a 3 door version
A 4 doors is more easy cause you dont have to completely pick the door panel of from the door...But it worked!
The switch is in the roof with the other lighting^^ so its completely working automatically.
And I didnt cut any wires! Cause i used a special connecter that i cut halfway and then i put the 2 wires and attached it all together
Lighting for a 42 mm bulb! Because it gives out more light and this one is OEM and completely transparant
The connector for the wiring (original VAG part... The flat piece i cut off and i used the other end for connecting a wire on a existing wire so I didnt had 2 cut in a wire)
The door panel from behind (so you guys know where to pull when you need 2 get it out of the car)
Then... running the wires for the unit. Ive rapped it around the original cables on the chassis
The unit in the side panel
And the end
And the end
