1 - 2 of 2 Posts
I have got a seat mii and just got a 14 inch space saver spare wheel from an older seat ibiza. The spare wheel fits fine in the space under the boot, but as I have had to remove the polystyrene type insert from this space, then there is a lack of support for the boot floor now. Is there an alternative polystyrene insert supplied if you have an official spare wheel? Or is there an insert available from, VW, Seat or Skoda dealers? The seat mii does not have the split level floor like the Up, so i could really do with something to support the floor. Thanks
Easy, I just did it a few days ago, I got some card from ceral boxes, so I got an exact template and then I got a sheet of 6 x 4 12mm exterior plywood from BQ for £14 and used a jigsaw to cut it out, smooth the edges and cut two holes in it to allow you to lift it out and works fully I then have the boot liner over it.
simple took in total about 30 minutes.
1 - 2 of 2 Posts
