hi, ive been lurking around on this great forums for a couple of month now, i think it about time i join and make a post
i picked up my little up! up around 2 month ago,
my up! story started after selling my mk4 r32 I've own for 6 years , didn't need to downgraded or anything, just wanted an up!.
day 1: just picked it up from the dealer, $12,000 with gps, emergency brake, power window, tints, mats and a tank of fuel, here it sits at my aunt house in Melbourne before a ~700km drive home.
was very impressed with the up on the trip home. other then driving for 5h with almost no visibility in heavy rain, i couldn't find the headlight adjuster so only 3-4m of the road was illuminated. but in the heavy rain and strong winds the up felt solid and safe, i had no trouble passing trucks and lorries while staying with in the speed limit
. i was trying to make it home on one tank but chicken out after 650km with the fuel gauge in the middle of the red zone.
day 2: up!'s home safe and sound and registered
day 3: coil over arrived from the uk
spent the afternoon fitting it. took me 20 min to install the back, 20 min to take out the fronts..........and 4 freeken hours trying to put in the new one
. the diameter of the weitec coilover body is slightly bigger then stock and i couldn't get the upright to open up big enough. gave up and went to sleep.
day 4: after a good night rest and searching this forum for tips, i got a 12mm bolt (iirc) and hammer it into the slit, the coilover slips right in!!!! when i knocked the bolt out, the coilover was not fully seated yet. i jacked up the upright until the weight of that corner is held up by the suspension and not the car stand, then taped the top of the upright with a hammer, the vibration loosen up the clamp a bit and the weight of the car pushes it in. all in all took me 30 min, sigh.
i don't remember the froum member who recommended the bolt method, dave i think. but thank you!!!!! who ever you are
the suspension is firm but not harsh for the people sitting in the front, but the rear passengers get tossed around a bit,
lowerd
Edited by: bot
Discussion Starter #2
day 7: a friend gave me a free set of enkei rpf1 15x7 with 195/50 15
toyo r888 and converted from lug bolts to studs with gold lug nuts!
driving around with semi slicks is supper funny!!! the car
handles a treat. sorry bout the pic its hard to see
day 8: took of the enkei with the r888 and swopped it with my set with more street sensible tires
killing time with freinds
day 8- today: after 5000km, the car have been grate, haven't been driving in a fuel saving manor but according to m&m im still doing 4.7l per 100k.
yesterday: had a spare BMC CDA lying around from my other project so i decided to fit it to the Up!
now it have a deep burble under load and you can feel the vibration from the sound through the firewall, couldn't stop giggling when i put the food down on the test drive, don' think it improve HP but it seem to breath better higher in the rev range. the new set up just need a screwdriver and 2min to remove and instal the old unit for when you get a service so VW will ever know
Edited by: bot
Bloody ****. I'm surprised that CDA fits in! My mates got one on his focus and they're huge things! Pretty though :)
Good work on getting it decked so quick :)
Out of interest, as I've never done it, how did you convert it from bolts to studs and lug nuts?
Stud conversions are easily available, you can find them on EBay.
In basic terms they are a bolt with no head, you screw them into the bolt holes with threadlok on the ends to hold them into the hub.
Voila! You now have wheel studs.
