21 - 30 of 30 Posts
So they vary...
Nevertheless, from fully stationary, if you start with foot on clutch and select reverse (or any gear), if the shift crunches, then chances are that it's a clutch-related problem.
Discussion Starter · #23 ·
Wife's 2017 UP! starts without foot on clutch. Just noticed this morning when I was defrosting it, switched engine off when outside the car to get something, then popped keys back in and started the car leaning in from outside, no foot on clutch. I will check again later when she gets in from work.
Yes mine starts without clutch which is very unusual on a car nowadays!
I’ve got used to always putting clutch so hasn’t noticed
As an aside, any car should be marginally easier to start and be a lighter load on the battery if you start with the clutch pressed (lower rotational masses by not having to spin the clutch back-plate and first-motion shaft)
Yep, I have always done the same on every car and motorbike. Only noticed the other morning that it did it when I was leaning into the car from outside to restart it when defrosting it.
Well, not if its occasional and o
I've instinctively dropped the clutch on starting every car I've ever gotten into for years, regarding of the tech it has.
Same here . Depress the clutch to start any car and also depress when switching off .
Much better ! Well done !
21 - 30 of 30 Posts
