It seems like I have whistling noise, and It happens only when it's cold outside, and while the engine is still cold (after a few minutes of idle). While in neutral, everything's fine.
But when I move, if I change the gears as the car suggests, everytime I go into the next gear, and push the accelerator pedal, the car starts making this strange noise, and it goes away as the revs get higher. The noise lasts for a few seconds. If I change gears at a little higher revs (~2500rpm) there is no noise. When the car gets hot, the noise goes away. So it happens for the first 2-3 minutes of driving. It seems to me (so maybe it's just me), that it happens more often when it's wet outside. The sound is very strange, and I can't determine the particular place where it comes from.
Anyone had the same problem?
Or it's not problem at all?
Thank you everyone.
Thank you everyone.
