Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
<div style=": rgb251, 251, 253; ">Here is the list of all front end bulbs:
<div style=": rgb251, 251, 253; ">H4= Headlight
<div style=": rgb251, 251, 253; ">HB4(9006)= Foglight
<div style=": rgb251, 251, 253; ">W21/5W= DRL
<div style=": rgb251, 251, 253; ">PY21/W= Turnsignal
Edited by: shakotanVIP
Right chaps, listen up and get it right.
The headlight is H4, I have tried M-tec HID class 60/55w which gives out 130/110w with a slight blue tinge, Ok but not as good as I expected. Have now changed to Phillips H4 X-treme vision which is a very bright super white light, far better than standard and the M-tec. Takes less than two minutes to change each side, can't see what all the fuss is about
Day running lights on mine now are M-tec T20 7443 super white, bulbs are blue but give off a very bright white light (make sure you order the duel filament) less than 30 seconds to change
Front indicators are Phillips PY21 with the chrome cap, far better than the yellow bulbs, they give a much stronger orange light as they flash back into the reflector, again less than 30 seconds to change
All mine have come from H.I.D direct in Manchester (on Google) exellent service, delivery within two days, either order online or by phone, the guys are really helpful
Hope that helps, all works perfectly in mine
1 - 2 of 2 Posts
Status
