My phone has been reset to factor settings and i cannot, for the love of God, figurer out how to Connect it with Maps and More by merely turning on it's BT when stetting into the car.
It is an Android Huawei P7.
Read Only
Andreas,
i may be stating the obvious here but merely turning on the Bluetooth will not connect your phone unless you have connected it previously using the pasword,usually0000.
Once you have connected it properly and saved the phone into the M&M memory it should connect as you get into the car without needing to press any buttons at all. I use an old SE Xperia and it takes about 20 seconds to connect itself when I get into the car.
