I'm starting to get a sporadic creaking on lumpy roads, at low speed, seemingly really low in the crook of the driver's footwell, maybe around the base of the steering 'column'.
It stops completely if I pull a bit on either the left or right parts of the crash-intrusion bar (between pedals and lower dash; it feels like 10mm rebar rod!). The bar in itself seems solid, weld-wise and it's firmly attached - I cannot create a creak noise just by pulling the bar around, so it's as if pulling it is affecting something else low down, and not the bar.
It's not the weather to strip stuff out and grope about low-down, and I'm not minded to go to the dealership just yet, given the repeated tries to sort out the rear shock that was noisy (they changed it in the end, to be fair).
I know noises often don't come from where you expect!
Has anyone had a similar issue, and if so, what was the root cause?
Car is 2019 Citigo 75 SE-L.
