Hi folks,
I was considering getting my Mii FR (75hp) tuned but a number of the suppliers quote an increase in bhp & torque less than can be gotten from the 75hp UP.
Is there a difference in the engines or is this some sort of VAG witchcraft?
If it was the increase quoted for the UP engine I would go for it but some of the increases for the Mii and 3 or 4 bhp & 5nm
Cheers
They just meant that most "cooking" Up!s with the 60ps engine can be 'mapped' to use the map from the 75ps engine. The torque is the same, but the 75 has more up to 25% more power after 4K rpm.
Both the the 60ps and the 75ps engines are the same mechanical unit, whether in Up!, Citigo or Mii - it's just firmware!
You may be able to squeeze out tiny improvements by careful RR tuning, but I doubt it's worth the expense.
