I wonder if you can help me, does the up, auto lock the doors as you drive off or is this missing from the design? Also, if not can all the doors be locked by the driver by any chance??
thanks
The answer is yes and yes. The car can be set up to lock all doors automatically when you drive off. It's not immediate but kicks in when you are on the move and beginning to accelerate. You can also lock the doors manually using a switch on the drivers door. I prefer to lock manually because you can lock straight away you can also unlock without switching off to allow passengers access. I assume this feature is not restricted to the high up specification.
But you have to ask your dealer to set it (unless you're versed in the art of VCDS) ""“ unlike other VWs, there's no steering-wheel-stalk-accessible menu option to set it yourself.
And, of course, both that and locking all doors by the driver require central locking, which the Take up! doesn't have.
