Hi
Recently fitted some 16cm pheonix gold speakers in to my doors using the proper speaker pods which fit many vag cars and save wrecking the original speaker! They are easy to fit and are a great improvement
also used some dyna mat sound deadening which works well. I just drilled out the rivets of the original speakers and the pods simply tap into the existing rivet holes (used spire clips) then cut of the speaker plug and crimped on two spade connectors. Then i screwed the speaker into the pod after connecting wires! Sorted
Edited by: TakeUpWhite!
