1 - 11 of 11 Posts
Ok guys this will not be to everyones taste but i just wanted to be different.
Alarm l.e.d. changed from red to orange.
Firstly remove door panel
It just unclips.
Unclip l.e.d.
L.e.d. unit
L.e.d. is hot glued into unit, i had to remove this and refit with this.
Lit up.
Took about a hour to change..
it's really difficult to get a photo with it flashing.
Will try ago when it's dark.
Edited by: gary02tdi
It's easy if you know what to do.
the door panel just unclips.
The glue is easy to prise out with a utility knife (watch you fingers)
Had to unsolder from the to pins that connect it to the plug.
Dave what type of fun you on about????
Seems like a lot of work to me I think a blue or green led would look better, but congratulations on doing different mod keep us posted with any more Edited by: Ian986
When i had my Golf (Grey in colour) with full blue l.e.d interior lighting.
Now I've got Dug the theme is white and orange.
I'm not interested in football and if i went down the blue or green colours people
would ask what football team i support?
I think it's time I bought a soldering iron!
Just fun with changing colour LEDs in the car. I'd like to change to blue, I bet you could change the dash ones too
Discussion Starter #9
Yes Dave thats the ones i used.
You need the resistor as well as the l.e.d.
Discussion Starter #11
I got the ones in the link, they come with the resisitor pre-soldered to the led.
I just cut the wire off and then soldered it too the pins?
Any problems let me know.
Gary
1 - 11 of 11 Posts
