Hello,
I have recently ordered an E-Up! and expecting delivery in late Feb/ early March.
I have seen conflicting information as to what charging cables come with the car from the dealership, does it come with both the fast charging cable and the 3 pin plug granny charger, or does this still need to be requested from the dealership as I've seen on other posts.
Hello,
Did you ask when making your order? The only way to know for sure what you will receive without extra cost.
It comes with a 32A type 2 cable which allows you to charge at 7kW. It also comes with a 3 pin granny charger (which is 10A). As per the brochure.
Are you sure that delivery schedule is accurate, that's a lot faster than what others are being told at the moment. Someone in the Facebook group said he was told it's a 45 week lead time if ordered now. Maybe you have a cancelled order?
I made the order through the work salary sacrifice scheme and they managed to pair me up with 1 of the 4 pipeline stock they've got coming into the dealership they use, the original lead time was 12 weeks.
I did also enquire about one of the e minis and the lead time for one those was 37 weeks
