1 - 3 of 3 Posts
My driver's side window sounds a bit 'Crunchy' when it's going up and down.
My last car's regulator failed on the driver's side.
Symptoms were similar on the old car, though louder.
Anyone else had problems with this?
Difficult / expensive to fix? (I think I paid £175 for the Fiesta.)
Thanks for any info.
first things first - check the glass itself is properly clean and more likely, check the inserts between the glass and the door on the outside are clean and debris-free. My car lives under trees and shrubs, and I get bits and lichen growth in the felt insert at the base of the glass that I have to clean out fairly often....
Okay thanks. Will take a look at that.
1 - 3 of 3 Posts
