I'm curious to discover whether any other forum users have had the engine of their Up! mapped. If so, has the expense been worth it?
Have you tried to use the search engine of the forum?Miserable Git said:I'm curious to discover whether any other forum users have had the engine of their Up! mapped. If so, has the expense been worth it?
In the case of the Up! it is a bit different, because there is an "official" remapping from 60PS to75 PS.UpMan said:I have remapped cars in the past and IMHO, it isn't worth doing. Yes, you get a bit of extra power and/or torque but you can just tell the engine has been messed with. hard to describe, but it just feels a bit 'off'...
Negative, the differential ratio is different in the two versions.uphu said:In the case of the Up! it is a bit different, because there is an "official" remapping from 60PS to75 PS.
I have heard this before but is untrue, power difference really is a remap. I will stand corrected if the gearbox and final drive are actually diferent. The parts CD lists just the one gearbox and final drive.Mulo said:Negative, the differential ratio is different in the two versions.uphu said:In the case of the Up! it is a bit different, because there is an "official" remapping from 60PS to75 PS.
No, I already knew where the engine was even without a map..Miserable Git said:I'm curious to discover whether any other forum users have had the engine of their Up! mapped. If so, has the expense been worth it?
