No biggy really, but I've always found my engine to be relatively slow to rev when, for example, pulling out quickly from a junction. Simple physics dictates that normally, the fewer the cylinders, the easier it is to get the engine to rev...
For a 3-cylinder, I find it pretty disappointing. Or is there a fault on my car?
Hi are you sure your not riding the clutch ,.some times as you say it's the norm ,the only other thing to do ,is when you are at a junction ,is to Waite till.its safe to do your manoeuvres ,it is only a small engine ,not made for high speedPhill
Duff star I thought the rev counter was the temperature gauge ha ha lol
Thanks for your replies and the link to the video - my problem isn't nearly as bad as that, and it has nothing to do with the clutch. I'm talking about the inertia in the engine. It's not bad exactly, just a bit surprising for such a titchy 3-cyl that it doesn't rev to, say, 4000rpm in about 1/2 a second...
