1 - 8 of 8 Posts
I was driving my up! white the 7 miles home from work tonight in the pouring rain, and halfway home in slow traffic, there was a "bong!" from the dash and the coolant light started flashing...
I had no idea what it meant, and as it was too late to get to the dealer, I risked driving home and THEN looked in the handbook to decipher the light. According to the manual, it could mean a fault in the coolant system.
I'll take it in to the dealership tomorrow first thing, but I'm really disappointed that my lovely new baby has a problem already!I've only done about 500 miles!
Anyone else had this show up?
It is worth opening the bonnet to check the coolant level - if it is too low don't drive it !!
However, it is just as likely to be a sensor issue.
Thanks David - I'll have a look tomorrow, but as the light is flashing as opposed to staying on, the manual implies your second suggestion may be the case.
I can't see how the coolant would be too low with it being so new, but I will check - I promise!
let us know what the dealer says and does for future reference, hope its just a minor thing :)
UPDATE:
Well - even though the warning light wasn't in evidence this morning when I started the Up, I took it to the dealer to get checked out.
The coolant level was exactly where it should be (and a very fetching shade of pink, if I may say so...) so they took my car into the workshop to plug it into the diagnostic thingummajig whilst I was given a cracking cup of coffee and biscuits.
The result? Zilch. Nothing. Nada...! Apparently nothing showed up at all, and the salesman seemed somewhat dubious that I had even identified the right warning light! Now, I'm a bit dippy, but not THAT daft! He muttered something about perhaps it was a sensor glitch, and that they had run the engine and checked the cooling fan came on, but there were no obvious problems.
So - I was sent on my way with the instructions to keep an eye on it and come back if it happens again! I guess it must've just been a temporary glitch after all...
Still - I can recommend the coffee...
Sometimes modern technology is more trouble than it's worth.
Glad it's sorted for you and you got your caffeine fix
Hi Elb
You said the warning light was during a wet drive home - did you tell the dealer about the weather conditions?
I'm just wondering if rainwater had shorted the warning sender unit?? If so it would probably be something and nothing and a squirt of WD40 will repel future water.
Discussion Starter · #8 ·
I did tell him it was peeing down with rain yesterday, because I couldn't see how it would overheat in such conditions, but he checked it for overheating. I think I'll do as you suggest though and give it a squirt of WD40 - I know we've got some at work!
1 - 8 of 8 Posts
