1 - 20 of 21 Posts
2013 Up! White. Jet wash caught fuel filler flap which pushed it open and snapped it off its bracket. If you look closely it's only glued to the bracket. Cover isn't damaged but it looks impossible to glue back onto the bracket, requiring an expensive refit of the whole unit meaning access behind interior trim. Anyone else had this problem?
Can't help you specifically, but thanks for the heads-up, I will be careful in future.
Just tell VW dealer it "came off in your hands" at the petrol station.
They should do a warranty repair..
It happened to me cost £80 if I remember right?
Just use a normal low pressure hose, car will be much happier all round
Here here !
Go well.
mine didn't come off with a pressure washer :( mine happened at the petrol station because some idiot parked to far back on the first pump causing me to park further back, so when I went to lean over flap to get the pump i knocked the flap and it came off with little force :/ lesson learned? wait for a good space at the pump even if there is a queue behind you :/ also I think it cost £120 fitted by vw.
Cant do that now!
Now you have posted what really happened??
Isn't that what's commonly known as lying? Would you be happy if the dealer lied to you about matters relating to your car? I think not!
just out of 3 years warranty, this morning when refilled, it just ready dropped when putting the fuel nozzle back, expensive to replaced
Walked into mine after leaving it open! I got a replacement complete in silver for I seem to remember about £60. Relatively easy to fit yourself.
Got mine from car being broken....worth searching eBay for UP breaking, then messaging the seller. Took me a while but got one in correct colour for £25 inc postage which I thought was very reasonable.
My Up's fuel filler flap snapped off.
VWupMedHumøret wrote in 2018 about repaired by plastic welding, what type of plastic to use ? would anyone help? I found his post with pictures but wonder what type of plastic he used?
1 - 20 of 21 Posts
