1 - 7 of 7 Posts
I got my high up in April of this year, about 2 months ago noticed that if I didn't use my car for a day or so, it is really hard to get into reverse and first. if I drive the car every day, no problem. Took it back to the dealers who left it for 3 days and said they had no problem with it!!!! Anybody else got this problem and is there a solution.
I get this with mine if I don't drive it for a couple of days.My solution is to put it in gear with the clutch down I then start the engine with it in gear.
I reverse of the drive then it's ok, no problem after that.
Thanks for the reply, I just start the car with key and then press clutch and go in reverse to drive off the drive.
On our Mii ecomotive, the clutch pedal needs to be depressed before attempting to start the car otherwise it won't allow it to start. I do this on all cars I drive irrespective. It eases pressure on the starter motor etc. I imagine the VW up! BMT and Skoda Citigo Greentech also require the clutch to be depressed before starting.Edited by: Timii
I leave number one on when parking, so no difficulties with first gear, to start I just press clutch before starting. I also leave hand brake on, so whenever I need to reverse and it does not go to reverse gear (quite often), I just release the hand brake and the car usually moves that tiny bit that you can put reverse on. I tought this is very common, but apparently not.
-eelis-
Edited by: -eelis-
1 - 7 of 7 Posts
