Well I finally got my 5-door up! white. Unfortunately it has only been made with front speakers
I've taken a rear door panel off and running wires for speakers (the doors are drilled ready for 6.5" speakers) looks easy. However, there is a wiring connector that is set in the car body that wiring to the door (through the rubber grommet) has to connect through; presumably for an improved seal.
Has anyone seen these connectors and/or do you know what wire connectors I need?
