Hi everyone
Driving home last night my high beam went off and came back on, i thought strange. I turned back to dipped beam and went to high beam and nothing, just side lights.
What should I be looking for?
Any help would be appreciated.
Thanks.
Check the relay, probably in one of the fuse boxes - I assume Ups have a relay for this like most cars. It might be duff, or might just have corroded contacts.
Point is, it is unusual for both bulbs to blow at the same time. Also check fuse contacts, but I doubt it's the fuse.
Monty
Have to agree with Steve. Old skool, check fuses, relays, connectors and if that all fails, THE BULBS !!
Not much else it could be unless the steering column switch pack has failed. Does high beam work when you flash the headlamps (as opposed to selecting high beam) ?
