Is it water or dirt? First Hoover it, thoroughly when it's completely dry which should improve it. Then I used a turtle wax upholstery cleaner which has a brush on the lid (can't remember the name right now). It's a foam that you spray on, rub in then Hoover off. If you use a stain remover, best to do the whole seat area in case it fades at all. Hope that helps.
