Ah, OK, thanks. I'll start a PM conversation in a minuteDefinitely naughty, but not as naughty as diesel defeat devices. Just be aware that the pdf might have DRM meaning only you can open it, or it might have a digital watermark that can trace it back to you. If you send it to me I can check it over.
Things like coolant and heating hoses aren't MoT check points but should be inspected at service; hinge lubrication; noisy gearboxes; erm..I will have a Service and MOT when the car is 3 years old in September this year. I will have this done at the VW main dealer (the final service on my service plan) and they price match MOTs.
I know a lot of the checks on the service and MOT are the same and i am sure they will not do the same checks twice. They will probably do the MOT first and then just the oil and filter change etc for the service.
Independent VW/Audi garage in Cumbria
Changed 3 spark plugs. Didn't do brake fluid as it was done in year 3
£295 all in. = £168 labour, £127 parts (plugs, oil, filters pollen and oil, sump plug)
I dropped the tyre pressures back down to a sensible 34, 32 straight after !
Where do you get your full breakdown cover for 30 quid? I assume that doesn't include recovery or home start.I can get an MOT for £30 and full breakdown cover for £30.
The base price for this Major service was £199, similar to yours.How much extra for the MOT and Breakdown cover? The VW main dealer service plan which includes all this, is around £400 a year, so it looks like your indie garage would be close to this price depending on the price of the MOT and Breakdown cover.
