161 - 177 of 177 Posts
whats your engine code?
Sorry, but I don't understand your question
the numbers on the new ones , that i have heard is 56 and 62 if it´s not the 29
you can´t use the polo ones since it´s a diffrent car and may have another ecu type
regards
Sören
You was right. The correct pin to my CYTA ECU is 56, a man that have tried to install in another Up! confrmed to me but he also told me that is not possible to activate the ccs in my car because the VW Brazil have changed the programming in this ECU version and even changing the coding using VCDS the ECU can't be able to read and to command the ccs. I don't know how far this is true, but if it is true, it is very sad. With the help of the Ciclo, a member of uk-polos.net, I change the position of fuse box wire to terminal 5 (SC5A), was supposed to be last mistake in my installation but the error continue to appear and doesn't work the ccs. I had a video showing what happens with the buttons and the main switch according of VCDS cable.
Thanks @RIX I relocated the pin and hey presto. All works!
Couple of problems I encountered following the post.....
1. To unplug the ecu cables I had to angle grind the metal brackets off that stop them being removed. It sounds drastic but I spent 2 hours trying to figure it out? I think on assembly at the factory they must pop rivet it all together..
2. I was heavy handed removing my headlamp light switch and broke it. Basically I turned to the left to remove not right ( while being depressed)
3. I swapped my bcm to a compliant one and as yet I haven’t been able to adapt the remote? I think it may be as I have alarms due to the broken switch? New one coming soon...
Overall would I do again? In short yes and I’ve gained a massive insight and knowledge but **** it was daunting. It’s cost me about £130 including bcm and 3 days on and off tinkering..
Sent from my iPad using Tapatalk
Well that didn't last long, I re assembled some of the car following the test drive and now its re assemble the drusie control doesn't work? Something similar to @matmaz ?
@RIX mentioned KL15 and KL30 and im assuming it the fact my supply is permanent and not switched and or as I have no diode fitted? All the cruise control is working on the test blocks but says implausible signal?
I also have a new light switch and have a few errors on the BCM around parking lights?
Heres the vcds log?
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (------CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 AL HW: 04C 907 309 N
Component: 1.0l R3 MPI H23 5972
Revision: UOH23---
Coding: 00110012022400000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020AL 001005
ROD: EV_ECM10MPI01104C906020AK_VW12.rod
VCID: 6582400664BDA7AE91-8030
1 Fault Found:
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 146511 km
Date: 2020.04.15
Time: 01:44:12
Engine speed: 782.50 /min
Normed load value: 18.4 %
Vehicle speed: 0 km/h
Coolant temperature: 98 °C
Intake air temperature: 56 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.088 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): status-Bits 0-7: 200
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible-Bits 0-7: 0
Acceleration: 0.000 m/s²
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 E HW: 1S0 614 517 E
Component: EBC 460 ESP H08 0012
Serial number: A00CTPU
Coding: 11BF247189AE02F9880224F691B04080590100
ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
ROD: EV_Brake1ESPMP1TRWVW120.rod
VCID: 312AE45660F53B0EBD-8064
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 1S0-937-09x-V1.clb
Part No SW: 1S0 937 090 B HW: 1S0 937 090 B
Component: PQ25 BCM H59 0563
Revision: -8------ Serial number: --------------
Coding: 74B82B0000010000000008042F28ACD000C0400C60020000200000400000
VCID: 3228EB5A6DF30016C4-8066
5 Faults Found:
03431 - Activation of Left Parking Light
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 146511 km
Time Indication: 0
Date: 2014.09.06
Time: 01:41:38
03432 - Activation of Right Parking Light
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 146511 km
Time Indication: 0
Date: 2014.09.06
Time: 01:41:38
03433 - Terminal 30 for Backup Lights and Adaptive Lights
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 146511 km
Time Indication: 0
Date: 2014.09.06
Time: 01:41:38
01516 - Terminal 30; Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 146511 km
Time Indication: 0
Date: 2014.09.06
Time: 01:41:38
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 146511 km
Time Indication: 0
Date: 2014.09.06
Time: 01:41:40
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1S0 919 475 A HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0009
Revision: -------- Serial number: 32961520902402
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA14VW1200000 001008
ROD: EV_EPHVA14VW1200000.rod
VCID: 383CD972838FEA46FA-806C
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag00R H02 0006
Revision: -------- Serial number: 003MY003H9JL
Coding: 000000000000000000000000000000003052
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D32C866ACADCF6E29-8068
Crash sensor for side airbag: driver side:
Serial number: 3495RRB401450KB8CGNI
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB401650KB8JI64
Crash sensor for front airbag: driver side:
Serial number: 3555NRB400250JHI698
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 960 N HW: 1S0 920 960 N
Component: KOMBI H31 0205
Revision: X0031012 Serial number: 00000000000000
Coding: 414220
Shop #: WSC 59897 001 1048576
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 3C34C562B7B7C6661E-8068
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 1S0 937 090 B
Component: GW-K-CAN TP20 H59 0563
Revision: -8------
Coding: 001300
VCID: 70AC2152A37F7206F2-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 960 N
Component: IMMO H31 0205
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A98333A8DA388D6BC-803E
Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 L HW: 1S2 909 144 G
Component: EPS_ECU H45 1503
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssisNSK_009_VW12.rod
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 D HW: 5K0 035 456 D
Component: KonzernAmp 8K H07 6615
Revision: -------- Serial number: EAA101A0005113
ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
ROD: EV_AudioVerst8KanalSTT3.rod
VCID: 2B16F63E42D951DE87-807E
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1S0 035 156 J HW: 1S0 035 156 J
Component: Radio H35 0063
Revision: R0000000 Serial number: VWZAZ1N0375816
Coding: 0001000801
End----------(Elapsed Time: 00:34, VBatt start/end: 14.2V/14.1V)-----------
disconnect the battery and try it again if it works 1 times , it´s ignition power that´s not iginition power but all the time, but looks like the ecu is saying wrong hole
clear all faults or it will not work
regards
Sören
regards
Sören
But it did work and I drove it a couple of miles and tested several times? Without stopping engine.. I then disconnected battery and re assembled some parts?
Maybe someone else will be interested. I am going to add cruise control to my e-UP. First of all you must check if the BCM supports cruise control. My BCM PQ25 has version Max4 H81 0744 with SW number 7E0 937 090 B, which is maximum level of equipment named also as High+ and supports CC. You can check this number like here, or use VCDS.
Good news! More original cruise controls are retrofitted in Denmark - but unfortunately not in mine (yet). Hopefully it won't be long beforeI find someone in my areawho can fit it.
There has been some discussion between members on the Danish forum, becausemembers who have alreadyfittedoriginal cruise control in up!'s hesitate to share their knowledge about theprocess as they fear they might lose potential customers. I must sayI understand them, but I'm sure it won't be longbefore a guide is "leaked"
On another note.. As we've already confirmed, material costs aren't that high if you have the right BCM (Body Control Module). Modules with one of the following OE part numbers are compatible:
1S0 937 087
1S0 937 088
1S0 937 089
1S0 937 090
All High up's and BlueMotion up's have compatible BCM's, but if you'd like to be sure if you have the right BCM fitted, it is possible to find out in just a couple of minutes.
The BCM is fitted on the back of the fuse box. The fuse box is easy to find if you look up under the dashboard. I'm not sure about RHD's, but on LHD's it's located to the left of the clutch pedal. Now comes the tricky part! The gap between the fuse box/BCM and the firewall is quite narrow and so it can be fairly difficult to get a view of the part number. I used a small make up mirror and a flashlight, but it is possible to take a picture with a camera as well.
This is a picture that I've borrowed from the Danish forum, Vagcars.dk:
That's all for now
Edited by: RasmusTJ
Do not forget to change the switcher. Part number is 1S0.953.503.AS
Steerling wheel control module should be like this 6RA.959.652.A
I will also add an electrical circuit that you may check, but it is in Russian, so use a translator.
Check connections and code Block 9 and Block 1 via VCDS.
Don't forget that you can code Block 1 only when the engine is off, for successful adoption of the encoding.
4900
I have not had time to conduct the wires, but I’m sure that this is a working scheme.
I'm trying to retrofit cruise using a kit, and I need to access the two plugs behind the BCM (fuse box) to insert the additional wires. I cannot for the life of me work out how the drop the BCM/fuse box to allow me to get my hand behind it to release the plugs. Can anyone please help?
It’s a real bitch of a job. You pretty much have to remove your lower dash, centre console and rhs trim. The plugs then have a locking tab/ lever that releases them. It took me a couple of hours first time but there’s no real short cut.
Once your lover dash is removed you can flex the fuse board and give you a bit more room. Just getting the bcm out is difficult let alone removing the plugs.
Sent from my iPhone using Tapatalk
Thanks very much for your reply. I don't think I've seen a more inaccessible control unit in a car.
I undid and pulled back the lower dash trim on the right hand side under the steering column, but still can't see how the BCM comes out. I tried to reach the plugs by sliding my hand behind it but couldn't quite reach. I don't see how you can get to the plugs without dropping the BCM and I can't see whether the plugs when released from the back of it will have enough length of cable to give me room to add the extra wiring to them. Wish I'd never started.
Did you actually manage to remove the BCM to access the plugs?
My bcm has been swapped a couple of times now so I think I’ve mastered it.. you have to remove it to re pin the plugs as the slack on the cables are limited.
The plugs have a retained clip that holds the plugs in place. It should be at the bottom and needs unclipping and pushing to the top. In doing this will remove the plug. Same on both side..
The bcm sort of clips in place both top and bottom.
Remove the lower dash completely as it makes all this easier. Then the Odb plug needs unbolting and the fuses sort fo move out the way. Also the rhs footwell trim need removing.
Then pull forward the relay mount and the bcm will jiggle out.. try this link may help?
Also message me with your email and I may have some destructions I can forward as an aid. Can post on here as not my property.
Thanks for all your kind help Deltabox. Unfortunately I'm deep in the crap with the job now. What a nightmare. I managed to snap the plastic fuse box mounting bracket when I flexed it to give more room as per your suggestion. Doing so did inadvertently clear access to the BCM but there is still almost no room to work as the BCM plug cables are so short, and I've no idea what I'm going to do about the bracket as the whole unit is hanging down loose on its wires now. A bigger problem is that I strained my back trying to get under the dash and now can't continue with the job. I can't even get back under to replace the BCM plugs, so the car is now immobilised. Instructions provided with the kit were crap too, totally inadequate and factually wrong in key respects. All in all the job has been a disaster from beginning to end and to anyone thinking of trying it I would simply say DON'T, unless you are a masochistic contortionist with tiny hands and time to burn. Totally p'd off with the car now.
Can you show me the way of the t16d/1 in the diagram, please? I need this to make sure the correct place to fit and I don't have this information.
On that sounds bad . The bcm has to come out and the wires pull through the gap. I found with the bcm snapped out of position the plugs went in easier.
I’ll be honest it’s the biggest diy mod I’ve done and it had its moments for me. I broke and had to replace my light switch. These task are never as easy as first thought. I hope you get it sorted.
