The interior light switch is next to the light itself by the rear view mirror. It has 3 positions, OFF-AUTO-ON. When in the middle position, should come on when you unlock the car, open a door or remove the key from the ignition. If you want it on manually, move the switch to the third position and it will be on all the time. HTH.
