I have connected my IPhone 4s to the UP with Bluetooth, however, when I play music music it only comes out of the left hand front and rear speakers. I have checked the speaker balance and it's fine.In fact if I move the balance fully to the right speakers no sound comes out at all.
When I use the radio as the sound source, everything is fine with sound correctly balanced out of all four speakers.
Any suggestions?
Sorry for the late reply.
I had a Similar issue when the M&M mount was not firmly attached to the car. If you push both sides down (the flat bit that touches the dash, you may here a click. It should be properly seated then.
Just happened to me this on my way home from work.
Thanks Mii al I've just been calling it all sorts on the way home.
It's amazing how many "faults" with the Up! turn out to be driver error!
