I tried to connect my ipod to my stereo but it only recognised a cd. Thinking it was the connector I tried it in my partners car and it worked. Is there any buttons I need to press to activate the aux or should it b picked up automatically. Thanks.
Hiya mate, there is a post on here somewhere which tells you how to get the aux to work. Can't remember exactly what I did, but I remember reading it here somewhere, but it was easy enough to do, as I had the same problem. For some reason the aux button is not pre programmed so needs doing manually-and the manual does not tell you that you need to, or how to do it!
Do a search and you'll find the answer.
Thankfully some one else already posted the solution-you're not the first, or I doubt the last to wonder how to get your tunes to work. Maybe one day the aux button may work without the extra work.
