I have an EPC light popping up every now and again, for seemingly no particular reason, then is goes out of its own accord. Pops up kinda randomly...I have tried to induce it by jumping on the brakes, accelerate hard, driving at 60 with high revs. Sometimes starting, it will be on, reverse out of my drive, and it will go off.
Snap-On diag tool shows historical P0327 and P0328 - which is the knock sensor. No other OBDs show anything. If I reset faults with the diag tool (even a normal OBD)...the light normally does go off, seemingly (odd....seeing as no faults detected)
So...went and bought a knock sensor and what I got does not seem to match what is at the back of the engine, where I thought the knock sensor was located ( under a little heat shrouded piece of material). Is this the knock sensor ? I didn't remove it, but did disconnect the wire, and a thimble full of water seemed to be "stored" in the plug, and hence thought "ah, that'll be why I was getting a random EPC....it had water in it". Drying, and spraying contact cleaner, reassembling, however, didn't seem to fix the EPC error
