Following an issue with our new Gti and a couple of other new cars on here this is the fix from VW Tech' via VW Customer Care.
Problem: UK map not visible in maps to download list.
Solution: UK is now part of the Europe map (some Brexit irony there!).
Problem: Map only partially downloads preventing the use of any functionality.
Solution: The map partially downloaded in our case as the phone (unknown to us) went into lock screen mode during the 30 minute download period. Do the obvious with the phone to prevent this.
Problem: Map will not overwrite the partial download when trying to re-download.
Solution: Delete the partially downloaded map by swiping the map designator, in the maps available for download list, to the left (which brings up a delete option) - this will then allow the map to be downloaded again.
Our M&M is now working perfectly.
Hope that this helps.
Thanks for the solution
Wasn't aware that my screen lock had come on as I could still see maps and more download screen which is odd to say the least
Dave
Dave
Same here.
