1 - 20 of 36 Posts
That's a really nice motor you have.
Hi Idi, love your car.. I was wondering, the ligth in the side doors does it work for the cabin also? or is it only visable when u open the door, and then it shine on the pavement?
Discussion Starter #12
Hi, i have taken the power from the roof lamp and wired out to the door, so its only turned on when cabin light is on.
And only visible when door is open, mounted in bottom
Thanks for the kind words
Edited by: ldi
Hi LDI,
Any chance of getting a picture of where you put the door light?
During the day.
Edited by: gary02tdi
Discussion Starter #14
gary02tdi said:
Hi LDI,
During the day.
Build in, i think i better find some pictures
Discussion Starter #15
Some pictures how the Shadow Light is mounted in the car.
The power to lamps, is taken from the roof lamp in cabine.
Lamp placement
Side view everything mounted
Mark where wire is fitted from inner to outer side of door, and connection house
Picture of wires in connection junction
Connection inside the car.
Discussion Starter #16
Some pictures of my Helix sound system and Fender speakers. The Helix system is from Golf/Polo, but can be fitted in the up, without problems. Still almost plug'n'play (some adjustment to pin configuration in connection to radio).
The Fender speakers fit in without any problem, here the pins on the connections has to be moved in front speakers, and new connection house to rear speakers.
Realy like the solutions, plays very well. Treble units (think they are called so) are standard, Fender does not fit without an crossover filter of some kind.
Pictures
Sub with amplifier mounted in buttom.
Custom made for the wheel tools
Front speaker mounted
Rear speaker mounted
Unit compare front
Units compare rear
Last the Helix logo
Discussion Starter #20
Added some extra rail clips
For your information, the part no. has changed to1S0 881 347 A 82V (thanks to Rix for info)
Edited by: ldi
1 - 20 of 36 Posts
