Hi Guys
I recently bought a six month old High Up! I am LOVING IT!!
Slight problem I have noticed, the light selector switch has a fault.
When in 0 position, sidelights comes on but interior dial lights off.
When in side light position, daytime running lights on but no sidelights,and foglights come on!
When in full light position, lights are on but without the sidelights.
Any experience of this problem before? Anything I can do to fix it?
Thanks!
Are you sure you havent got the DRLs confused with the side lights? DRLs are brighter than side lights, i have a take up so i'm not too sure about the fog lights but everything else sounds normal i think. To operate the rear foglight on take up you just pull out the switch though.
Maybe if you could take a picture of the lights and the corresponding switch position, if that makes sense.
As yea, a second read I'm not entirely sure whether there is a fault or not...
I had symptoms that sound very similar or exactly like that. I took it into the dealers and they replaced the switch. The dodgy selection stopped.
The fog light warning system is bonkers, but at least it now works.
Good luck,
Mike
Edited by: ducatikid
