1 - 1 of 1 Posts
For those who have/use M+M: when you programmed a journey/destination, Expected Time of Arrival is the default mode.
Found out that you can actually easily toggle between Expected Time of Arrival (ETA) (scheduled time when you arrive at destination - default mode) and Expected Time Required (ETR) (how many minutes are still required to reach destination): just touch the ETA/ETR square/indication below on the right hand side of the M+M screen to toggle between ETA and ETR and vice versa.
If you programmed an interim destination, both timing settings (interim destination + final destination) change from ETA to ETR and vice versa when you touch one of the ETA/ETR squares.
Pretty sure that this is mentioned in the manual but, like many of you, I prefer exploring new stuff myself and check the manual when needed.
1 - 1 of 1 Posts
