Jaws said:
a) Anyone else had any issues getting it to fully charge and show green?
b) Also is there a way to get the screen just to show where you are without setting a route and destination?
b) Yes - just tap on Navigation then, via Options, tap on Show Map.
I have printed out all 140(ish) pages of the manual - and have studied in depth the Maps section and also the ON/OFF mounted and unmounted sections because I have a problem!
It should normally go into standby when the ignition key is withdrawn, and it should turn back on when the ignition is next switched on. It has always done this except for two occasions where my Unit has turned itself off whilst mounted in the car. I've had to operated the "Press RESET with a sharp point whist pressing the On/Off button at the same time."
If it happens a third time I will return it for a replacement (which the Dealer offered the first time it happened!)
a) Suggest you leave it for a good long time (say 24 hrs) to fully charge (either via USB or mounted in the car). If still amber, then something wrong with unit?
