I have tried to use My sat nav in my other car pluged into 12v power outlet. but it will not charge while connected via USB if the device is on. The on screen icon shows a two pin plug. Manual says this means that the battery is fully charged. However the unit is running off of its internal battery and shuts down once battery goes flat. Does anyone know if this is a fault? It seems that it will only charge via USB with the Satnav turned off.Edited by: Ptpole
