I've had my up for three months now and haven't really used my maps and more much as I'm learning to drive. The times I have used it I've been left feeling slightly disappointed with it.
Firstly when I have been playing music via Bluetooth from my iPhone the music will skip every few minutes, this is highly irritating and ruins the experience of the music.
I emailed navigon about the problem and my view of them went right down. They told me the solution to my problem was to play music off an sd card. I sent them an email straight back saying how bad of a resolution to the problem that was. They quickly responded telling me to reset the device to fix the problem. I haven't tried this as I have been away but will do and hopefully will fix the problem.
The next issue with the device is that it will at times get confused and think that I have turned off the correct route and tells me to turn round. Of course I haven't gone off the route and the turns in the road have confused it. Not that big of an issues but irritating never the less.
The final issue is clearly a large fault. When abroad and I tried to use the sat nav it sometimes would not power on, it would show the first splash screen and then switch off. I tried two different chargers and it did the same with both so clearly isn't a power issue. After probably fifteen minutes of trying to turn it off it finally turns on however it would then power down at random moments while in navigation leaving us clueless as to which way to go on Italian roads!
I am going to go back to vw and see what they can do as this was an expensive option for essentially a garmin sat nav and so far I have not been impressed with it!
On the upside there were loads of ups in Italy which was good to see, I think the fiat 500 was more popular though!
