Yep the 0-60 is about the same as a DSG 2020 Golf GTi. But much faster once going as traction and 2 gear changes hurt the 0-60 time.That sounds Insane!!! I bet the 0-60 is not far off the Golf GTI.
Excellent mod. Is this the real carbon mirror covers or the Carbon fibre effect mirror covers? Because there is a significant price difference. I assume you have to remove the old covers to fit the new ones?
They are the real ones. Defo worth it for how they look up close.Excellent mod. Is this the real carbon mirror covers or the Carbon fibre effect mirror covers? Because there is a significant price difference. I assume you have to remove the old covers to fit the new ones?
JBS could probably tell you more about what the intake temps get to, but in real world the car has been absolutely fine and certainly does not seem to get too hot. I have done nearly 14k miles now with no problems other than a faulty MAP sensor at the end of last year but since replaced it has been faultless.Super impressed with your build. Will probably follow the hybrid route after stg2.
I am a bit worried with the chargecooler performance with a hybrid turbo installed.
How are the intake temps so far?
Stock chargecooler cant be removed since its integrated in the intake manifold, adding an intercooler will add significant lag.
One possible solution is replacing the radiator for the chargecooler with something better (?)
