1 - 3 of 3 Posts
I tried to restore my Navigon and halfway through the flashing there was a power failure so it's now no longer recognised by Navigon Fresh. and my Navi is empty. Anyone that has a backup of and old vw UP navigon. only the system file not map. i can get my map from Fresh when it can se my navigon.
@bumbleMii, would you mind if i attempted to use your restore on my navigon, It was looping on boot up, I cant for the life of me find garmin fresh to try and sort it, the software appears to have been deleted from every source on the net, I have also just replaced my battery in the nav (so if anyone needs the part number before opening the unit , its 361-00051-02 (3.7v 1.25Ah, 4.63Wh.
Its frustrating as when the units plugged in I can get in files on the built in flash drive.
or if anyone is able to point me to a downloadable garmin fresh installer. Im aware its out of date and not supported but would be appreciative if I could at least rescue the unit.
1 - 3 of 3 Posts
