I can’t tell if it’s too low or if it’s just the deficient grips and their lack of sidewall! I’ll give it a bit longer and see how it goes, I do plan adding spacers and eventually wider tyres.
Looks well, I guarantee you the noise is coming front the front and only over larger holes in road, have them raise it slightly, actually just take wheel off and use the spanner as it takes a few minutesView attachment 8588
Photo for height reference
I’ll try to grab a better example tomorrow, it definitely looks even all the way around to my eye. In terms of the finger test, I’m also at 2 fingers all the way around as well so sounds like we’re quite similar there.I think with the back lowered more than the front and making the arch gaps pretty even is the sweet spot the photo you posted wasn't the best for seeing the arch gaps...
With a full tank from the centre of the tyre to the wheel arch I have a 2 finger gap front and back maybe a touch more front
Yeah I need to sort the rear as it looks proper w#nk on mine :0 What bolts are needed then?I started with the rears they are very tucked in I'm led to believe the track is 10mm's narrower on the back so 5mm wider spaces on the rear sort that out
My advice is put the front spring perch up by 3 full turns both sides which makes hardly any difference to the cars height I did this several times and no noises at allI also occasionally get a slight knock/ thump like you're describing, when going over speed bumps a bit too fast (or maybe not fast enough). Could be knocking against bodywork / spats I suppose, but no evidence of rubbing. I also wondered if the springs were shifting in their seats occasionally but I don't know.
This may be a really stupid question with a painfully obvious answer but... can you adjust them on the fronts without jacking/removing the wheels?My advice is put the front spring perch up by 3 full turns both sides which makes hardly any difference to the cars height I did this several times and no noises at all
