1 - 2 of 2 Posts
Hi folks
I have no radio signal - just white noise, apart from randomly, bbc radio 4.
There are loads of threads about poor signal, which I can see.
Could anyone advise if there is a concrete fix for this. E.g, new antenna or new base or both or something else?
Cheers
Assuming the radio electronics are not fried, white noise does imply no signal, but logically that could be a number of things - loose or corroded connection to antenna wire at the back of the radio, cut antenna wire somewhere, loose or corroded connector at the antenna, or it is a powered type, and I'm not sure what Ups have, it could be a failed antenna (or loose/corroded power feeds to it). You may have to pull the radio, check the back, and then buzz out the antenna wire to the antenna itself....
Is it a DAB radio?
Have you tried a 'factory defaults' reset on the radio?
1 - 2 of 2 Posts
