1 - 8 of 8 Posts
Hello peeps
Just bought our first up today and can't for the life of me figure our how to get any sound on the stereo ??
Even removed the 'maps and more' dashtop screen and still nothing ??
Can't find a mute button
Any ideas ?
Do you think this is a fault or just an incorrect setting ?
Paul
I just have the German Skoda manual ...
Did you first push the "main left" button for on/off and then dial the same button for loudness?
As far as I have seen there is only a mute mode when you have "back driving detection" (what is Rückfahrhilfe in English?). If you are in reverse mode/gear, the radio is muted ...
Did you buy a new or second hand up?
Bought it used but from a VW dealership
Ignition on
Press left button to turn stereo on
Volume up
Nothing !!
Select any radio station
No sound
Argghhhh !
Quick update - on the touch screen display there is an icon that looks like speaker / volume 'icon' this is blanked out ? All other icons are fine / present ?
Any ideas ?
Hi mate,
Did you ever sloved the issue from the muted radio? I have exactly the same issue. No sound from radio, aux, maps, phone. And the speaker seems to be grayed out on the navigon.
Thanks!
I've fixed it. I noticed that sometimes a 'short to ground left front speaker' code popped up. so I cut the wire at the speaker end. and I cut the wire at the radio end. then I soldered a new wire in between. This solved the issue.
Seems there is a safety measure built in that checks the wire half way. If it finds a faulty wire it shuts the audio system down.
Cheers guys
1 - 8 of 8 Posts
